Not interested in any of these until there's a version with G-Sync or something equivalent.
Tearing and vsync lag are just as unacceptable as motion blur and shitty contrast.
Way to let the entire forum know you're under the age of 16.
55" TV...
The cost to manufacture smaller OLED displays is still too prohibitive.
Don't know about OLED being suitable for monitors but there is a Sony professional OLED monitor already produced, if LG charge £2000 for a 55" 1080p then they would surely make a good profit from a small monitor priced around £700.. and loads of people would buy an OLED monitor at that price. Maybe they are waiting until they can produce OLED monitors at lower prices.
The latest LG OLEDs have anti-image-retention mechanisms that are run every so often to help combat the issue. This is for normal TV viewing and appears to really help. Throw all of that out when you're talking about always-on PC monitors.
Even if the cost would be acceptable, there are other issues which are not entirely in favor of OLED: image retention and need to control brightness.
So, the bottom line - the problem isn't production cost or technology related issues, the problem is the demand for better picture quality.![]()
I turn my monitor off whenever I'm not using it. I'm assuming it'd be ok for the few people like me.
Yes, you are right: mass consumers decided the present LCD PQ is good enough. OLED can compete only in the upper segment where PQ is of certain significance. This does not mean however that OLED has no chances to succeed in the market driven by price. Only recently LG started mass manufacturing of big OLED TV displays and they have plans to expand capacities and lower the prices. We may see competitive OLED TVs within the next 24 months. Later, in case OLED grabs certain market share smaller displays may arrive and eventually OLED monitors.
On Tuesday, however, LG said that it has made significant headway in developing OLEDs. The company touted its position as the first to mass-produce large-screen OLEDs for televisions and said that its yield has hit 80 percent -- a strong showing, but still lower than LCDs.
LG Display said Tuesday it expects to sell 600,000 OLED TV panels this year and 1.5 million next year. The company also cited comments made at the press event by Ching W. Tang, a professor at the University of Rochester in New York and "the father of OLED." He said OLED displays will not become ubiquitous for another five to 10 years. At that point, Tang said, they could outpace LCDs in total shipments.
I doubt it. Greed is likely the real reason.Small OLED panels are commercially viable because they're small. Small panels means less panels thrown away due to defects (which are a function of process scale and size of substrate)
Big OLED TV panels are only commercially viable now because of a switch to fabbing only white OLEDs (wOLED) and adding coloured filters over them. This cuts down on the number of process steps needed, again increasing the yield.
Desktop monitors are not yet commercially viable until either the small-OLED panel process (RGB organophosphors) can be scaled up with yield improvements, or wOLED can be scaled down without increasing the defect rate due to feature-size.
How will LG.Display sell their crappy IPS panels with terrible uniformity if they release superior OLED panels?
OLED tv's aren't doing fine right now at all.
^I would say OLED might be the future since LCD will not give up easily and is good enough for mass consumers. At this point one can say OLED has chances to establish itself at high-end TV segment, to take significant part of the TV market would require OLED becoming cheaper than LCD which is not yet in the cards.
I would hope a technology with an even more impressive form factor and a vastly better picture would not have to be cheaper.
any [H] members actually using one of these OLED's as a monitor ?
I really want to pull the trigger on an LG 55EC9300, but 1080p seems so small at 55"s :\
There really is no high end consumer market. Pioneer use to own the high end market, and stopped producing their Kuro line TV in 2008.
You forgot to add dim, washed-out in anything but a dungeon, severely size-limited, boat-anchor, 60hz flicker-fest to plasma's shortcomings. The fanboys pretend there are no other reasons to blame than "nobody goes for picture quality anymore". lol
The only reason LG is dumping hundreds of millions into OLED is for gimmicks? Really? Time to generate yet another new account name.
Sony proudly introduces the BVMX300 30-inch *1 4K Oled master monitor- the flagship model in its professional monitor lineup. This new monitor offeres the inherent performance of TRiMASTER EL OLED monitors, Including unparalleled black performance, color reproduction, quick pixel response and industry-leading wide viewing angles. In addition, the BVMX300 supports high dynamic range mode and a wide color gamut conforming to DCI-P3 and most of the ITU-R BT.2020 Recommendation.*2 By unleashing these superb features and qualities this master monitor makes an ideal tool for a wide range of applications such as color grading and QC (Quality control) in the 4K production workflow. *1 750.2mm viewable area measured diagonally. *2 The BVMX300 does not cover the ITU-R BT.2020 color space in full
Can only imagine what this thing is going to cost.
https://pro.sony.com/bbsc/ssr/cat-monitors/cat-oledmonitors/product-BVMX300/
Looks like we may see some OLED monitors from LG next year
http://www.oled-info.com/lg-display-enter-professional-oled-monitor-market-2016
Pretty sure small to medium is something like 2" for smartwatches to, maybe maximum of 10 or 12" for tablets. I don't see pc monitors based on OLED for a long time (maybe never?)
