Hey all (Sorry this is kind of long, been a twisting path of an upgrade saga so far)
These are old Specs:
alright, so I already have dropped $235+ into oldgrading my primary. Also, I'm running XPx32, where I rant into the 3 gig limit. Need all that ram for Photoshop. So am going to have to migrate to Vista x64.
Realizing this, decided that everything needs to be faster, and I want a 64 bit capable pro on both of my systems. So I have grabbed more hardware to that end. For price reasons, and because of my abundance of DDR (I have 4x1GB set, 4x512MB set, and 3x512MB set), decided to stick with NF4/Socket 939 stuff. So doing a little research I got the following stuff
So, not wanting to spend more than another $100 or so, what you would buy to finish up this Upgrade.
So, I've been running a dual system setup using the Synergy software for a couple of years now. (I bought a new case and ended up building two whole systems, one frankensteined from the old parts, and one new stuff. One attached to 19" LCD, another to old 17" CRT. (Need to upgrade to like a 20"+ SIPS panel and want a Trinitron 21").
Primary:
Epox 9RDA+ NF4
Athlon 64 3000+ 1.8Ghz (Venice)
4x512MB of corsair value select cas 3 DDR400/PC3200
Nvidia 6600GT 256MB
73GB 10K Seagate SCSI
146GB 7200 Seagate SCIS
29160N (Yes, I refuse to give up this damn card, I spent $200! on it, and that was in like 1998 dollars or something, besides I was finally able to afford a 10K drive for it!)
plus an IDE DVD burner/DVDROM/CDRW & floppy.
attached to 19" Hyundai L90D (I need a 20" SIPS panel so bad)
Apevia X-Super Alien Full Tower
OCZ 600W somethingxstream (Have to look, could use an upgrade)
Secondary:
Epox 8RDA+ NF2
Athlon XP-M 2400+ (Barton) running 2500Mhz (200*12.5)
3x512MB CAS3 Micron DDR400
AGP Nvidia 6200GT 128MB
Maxtor 80GB IDE primary drive
Seagate 750GB SATA
IDE DVD-Burner/DVDRom & Floppy
attached to ancient 17" CTX CRT (I think it came from my P133 system back in the day)
original In-Win Q500 FT Case
Rosewill 500W? (need to look, & upgrade))
So, this is old shiat, The primary use for these computers is to webdesign/photoshopping on, plus office, quickbooks, etc, with a bit of gaming (FPS/RPGs like FO3), lots of web browsing, downloading, mp3s etc.
Which brings us to my Oldgrading Saga. OK, so I've been checking out Adobe CS4, and decided I needed to upgrade to 4Gigs of RAM, so I dropped like $110 on 4 Gigs of Cas 2.5 DDR400 (which has pretty much wedded me to NF4 era stuff at the moment, don't want to invest in more memory at this point.) Also upgraded to a Galaxy Geforce 9500GT with 1GB of GDDR3 ($96 new from the egg). Then decided to grab a faster proc (that is like the slowest Athlon 64 pretty much.) So snagged a Athlon 64 4000+ (San Diego) for like $35 off of the forums and popped it in my primary machine. It's current config is..
Epox 9RDA+ NF4
Athlon 64 4000+ 1 (San Diego) 2805Mhz (11x255)
4x1GBMB of Gskill cas 2.5 DDR400/PC3200
Nvidia 9500GT 1024MB
2 Opteron 165 dual cores, 1 in hand, one in the mail. (Spent like $125 for both of them)
Gigabyte
Gigabyte GA-K8N Pro-SLI (NF4 SLI board) ($53.75)
Gigabyte
So I've already spent $400 upgrading/buying parts. I was wanting to grab another NF4 SLI board, preferably a DFI lan-party or ASUS A8N SLI, but any NF4 SLI board that is $50-$60 if I can get it. Main reason is that the Epox 9RDA+ Ultra I has is old enough that the PCI.e slot on it is 1.0a, and the new PCI-e 2.0 card are only backwards compatible with PCI-e 1.1 slots, or so I read. Thats why I got the GF 9500GT instead of a radeon HD 3870. Also, the SLI boards will give me more upgrade options and support more SATA storage. (Will be needing more storage over long run)
Currently on my shopping list is a NF4 SLI board to swap out for the Epox 9RDA+ on my primary, and a set of 2x1GB DDR400 to upgrade my secondary to 3Gigs of Ram. So Vista x64 will run well on it too. (I also want a 3rd NF4 board, so I can build a mom box that can run Vista as well, so I only have to support one OS on my systems).
So any recommendations/advice. Any of you been reduced to oldgrading? First Time I haven't had cash to upgrade to newish/new hardware.
