OLD PC, about to fly out the window...
orion23
So this has become more of a challenge than anything else...Hi!
Trying to fix and old PC with about 512MB of RAM.
I removed all PCI cards and the only card in use is an AGP 8MB VGA.
Windows XP Home Edition.
PC will work for a little while and then it will freeze. Sometimes it freezes @ the welcome screen, or the video signal goes missing
Other times, it will make a horrible noise (kind of like a modem dialing) and then it freezes or loses video signal.
I installed XP Pro to a different partition and different HD and the same problem occurs.
REPLACED PSU, HD, RAM, VGA, AND REMOVED ALL PCI CARDS, FLOPPY, CD-ROMS.
Cleaned CPU and re-applyed CPU thermal paste. Cooler runs "cool" to the touch
Same thing.
Weird thing is that the computer will allow me to install Windows, which takes @ least 1 hour in this system, but it will crash when trying to run for the first time, @ the welcome screen, or a bit later after loading.
With the old installation (HD), I cannot even make it to the welcome screen anymore. It just dies there and reboots again!
toss it. Not worth the hassle. can you even run 1024x768 with 32bit color on a 8mb card?
I have 2 perfectly good non-upgradable Toshiba laptops that are in the same boat...can't run anything but W95...they make nice bookends :D
Have you tested the RAM? Download, burn and run Memtest+ for at least 3 hours to see if there's any RAM problems. Run Memtest for 24 hours if you want to completely rule out the RAM. One error is more than enough to screw up the system.
