old mobo needs AUX power connector (!?)
venm11
I have an old PC whose PSU has failed and needs replacement, but it's an oddball PSU. It requires an AUX 6-pin (the old-skool AT connector) in addition to the 20-pin ATX connector. Dell and others did this for awhile, so replacements could be still available, but I'd prefer to use some kind of adapter with a standard ATX psu.
This PC needs to get fixed rather than replaced, because any replacement will just be too newfangled (don't ask).
http://en.wikipedia.org/wiki/ATX#Issues_with_Dell_power_supplies
http://www.playtool.com/pages/psuconnectors/connectors.html#aux
Ideas?
Depending on whether the mainboard is 5V based or not (if no ATX12V connector, it is), you're going to have to take care to select an appropriate unit. Many if not most newer supplies aren't designed for high 3.3V/5V loads. The key spec to look for in that case is a combined 3.3V/5V rating of at least 180W.
That said, you might be able to find an old FSP530-60GNA around somewhere - they will support such loads with no problem at all, and should have the correct connector already on there. Mine did, anyway.
These PSU's were designed for older systems where the CPU is often powered from the +5V rail.
However these still provide enough +12V amperage to run most of today's lowend to midrange systems.
[Many Different Versions, many are 20-pin ATX Only]
ENERMAX EG365AX-VE(W) / EG365AX-VE(G) / EG365P-VE 350W
Output +3.3V@32A; +5V@32A; -5V@1A; +12V@26A; -12V@1A; +5VSB@2.2A
Specs: http://www.enermax.com.tw/english/product_Display1.asp?PrID=29
From $25: http://froogle.google.com/froogle?q=EG365P-VE&hl=en&btnG=Search&lmode=online&scoring=p
ENERMAX EG465AX-VE(W) / EG465AX-VE(G) / EG465P-VE
Output +3.3V@35A; +5V@35A; -5V@1A; +12V@33A; -12V@1A; +5VSB@2.2A
Specs: http://www.enermax.com.tw/english/product_Display1.asp?PrID=28
From $35: http://froogle.google.com/froogle?q=EG465P-VE&hl=en&btnG=Search&lmode=online&scoring=p
[20/24-pin ATX]
VANTEC ION 2 VAN-460N ATX12V/ EPS12V 460W
Output +3.3V@28A; +5V@30A; -5V@0.5A; +12V@30A; -12V@0.8A; +5VSB@3.0A
Specs: http://www.vantecusa.com/p_ion2460.html
From $50: http://froogle.google.com/froogle?s...=VANTEC+ION+2+VAN-460N&lmode=online&scoring=p
This is my #1 Recommendation for this class of PSU's.
[20-pin ATX Only]
PC P&C Silencer 360 ATX 360W
Output: +5V @ 30A, +12V @ 21A, -12V @ 0.8A, +3.3V @ 26A, +5VSB @ 2A
Specs: http://www.pcpowercooling.com/products/viewproduct.php?show=S36ATX&view=techspecs
$36: http://www.pcpowercooling.com/products/viewproduct.php?show=S36ATX&view=about
http://forums.extremeoverclocking.com/showthread.php?t=136602
These are designed for these older +5V powered CPU systems, but will probably still need an adapter.
Best Wishes,
Dave:)
Guys, thanks for your information and thoughts. It was difficult following up this week with all the outages on the site.
I'd prefer to buy a standard, modern ATX PSU because I can repurpose that if this machine can be replaced. Adapters are apparently available:
http://mypccase.stores.yahoo.net/20pinexcowi6.html
What is significant about this 180w capaticty on 3.3v+5v? Does it relate to a part of that earlier atx standard? I ask because it seems like only fairly expensive PSUs can deliver that nowadays, and this is a crappy old P3-800.
You will probably cross-load a modern PSU, you need an ATX1.3 or similar.
Older mainboards require large amounts of power on the 5V rail, and sometimes the 3.3V as well. If that rating isn't high enough, the PSU will crossload and fall on its face regardless of how much 12V power it has.
There are some units with a high combined 3.3V/5V rating that will turn around and power a decent 12V based rig, but they tend to be server grade units. The Silverstone Zeus ST56ZF is one such unit.
