Ok I do freelance computer repair and I've been doing it for a few years now.. I thought I had saw it all until now. I have been messing with this computer for 3 days now and I've exhausted every possible option that I can think of, including googling for answers.
The computer itself is a 950mhz Athlon, with a kt133a or kt133 chipset, not sure which. It came stock with 64mb of ram, and obviously you need more than 64mb of ram for windows XP to run decently. So I got XP installed with the 64mb until I got the upgrade. I aquired 2 sticks of pc133 256mb, one micron, the other generic. When I install either stick I get the same symptoms, no matter what configuration I try. Leaving the 64mb in or taking it out doesn't make a difference. But here's what happens.. The BIOS detects it fine, but when I try to boot into windows, it does the loading screen, the keyboard and mouse initialize, blah blah, but then it looks like it's going to go into windows, but alas a black screen appears for about 20-30 seconds, then you can hear the hard drive give out, and the computer restarts. Booting in safe mode works PERFECTLY. It see's the ram, everything runs fine. This computer is worthless without a memory upgrade, but alas, it cannot be upgraded. I am using the specs that gateway recommends for this machine.
ANY IDEAS would be absolutely appreciated
Thanks,
Matt
Thanks,
Matt
