Old Computer good enough for university life?
alexyang
I'm entering university next fall. Would bringing a computer with the following specs be sufficient for university (general use, mostly non-programming and non-gaming) use?
Dell XPS circa 2000
Pentium III @ 800mhz
128mb PC800 RDRAM
Nvidia TNT2 Riva 32
30G ATA-66 HDD
19" CRT
Or is it just too old?
Can it be used as a desktop in conjunction with a laptop?
It is a pretty old system but if you're just using it for word processing, researching, online work, etc and not for gaming or running powerful applications then it should be sufficient. If your laptop is better then use that for any programs you need to use for classes or for games and there's probably no reason to upgrade the old computer right away.
For word processing, it'd be alright but I'd prefer more than 128mb. It might be expensive to upgrade though, RDRam is pretty expensive now (nobody produces it anymore.)
Still, with win2000 and a lot of services turned off, it could be usable.
It really depends upon what you're doing.
I do some programming, lots of Visio work, image editing, flash development, and publication layouts (typically all at the same time), and I found that a p4 2.8 with 512mb of memory wasn't enough.
My GF does mostly basic stuff, but sometimes she'll have to use a 3d rendering program for either chemistry class for molecular structures or for bio with proteins. Her Dell 600m laptop with a P-M 1.6 and a radeon 9000 is enough.
Thanks for the responses.
I plan on buying a Macbook when I graduate from HS next May.
The Dell XPS in question runs Linux, and I figure it could still be useful as a desktop in a dorm setting.
I definitely wouldn't use it for any programming, gaming, or video-editting. But, I think it functions as a jukebox and word processor quite well.
I would try to find some rdram cheap in the meantime but yea you can get it to run ok for some real basic stuff. Personaly I would try to get something better though. I mean for 200 bucks you could get a 512 stick or ram, mb, proc, case and ps. Could prob get a hd in there too if you go with some used parts. Would work a lot better.
It will work for that I have my old P3 800 sitting in the corner of my Dorm for when I screw up my good box I can still do my homework. It will do anything you want but game
Might want to look into some more ram though. I have the exact same system you do but a gateway with 384mb of SDRAM and it runs Linux and XP just fine.
Which Linux distro are you running on that XPS? With that low amount of RAM, I'd go for a much lighter desktop, like XFCE or Fluxbox.
a friend of mine was talking about getting a computer from the university surplus warehouse.
I really didn't like the idea and said why for about 20 mins, and he kept begging me to come with him to just take a look to see if there's anything decent.
Turns out, they had about 10 computers with 17" CRTs for about $100 each.
He purchased one with an Asus KT333 motherboard, AthlonXP 1800+, 512MB DDR, and 80GB HD, cdrw, sans CRT for $84.
I'd say it was a really good deal, but warned him about the psu.
I think he may have me come over to see if it's an okay psu.
so you may want to see if your university has anything like that. A ton of old junk, very cheap.
they had an old Willamette P4 system with 256MB RDRAM for $125. I couldn't believe it was more than the Athlon XP machine.
To the OP, your XPS should be ok. I remember freshman year in college all I got was a P3 550 Mhz, 128MB Ram with W2k and it did its job. Also forced it to run Counter Strike (when the virtual mem kicked in). :eek:
Also might want to check out the university sales as the poster above me said. I had a roommate that picked up a crappy old Dell system for 50 bucks. Dunno what he uses it for now but the peripherals were probably worth more than the computer itself.
RDRAM is really expensive and that looks like the weakest point in this... XP uses like 200mb by itself and office XP or 2003 is big also..
Id go to compusa and there is a box set MSI LGA775 w 2.8 P4 for $200 add a $75 512mb of DDR and you are set.. for >$300
sell your dell to an unsuspecting sole or sell the RDRAM on ebay, keep the HDD and go office space on the case... :)
i know compusa ram is mor eexpensive than newegg.. $20 more... so get the RAM of newegg if you can wait 3 days... some people cant
honestly something could fail on you and it usually does when you really need it.... id build something new for under $300
a P4 system or a AMD 754
it can be done for close to $200
Budget systems are cheaper if ordered online...
Here's a Pentium D, Dual core, upgradable to Conroe... for under $200:
$50 - AMPX 512MB DDR2-533 3AXD2533-512M1S-R
$55 - ASRock 775Dual-VSTA Socket T (LGA 775) VIA PT880 PRO
$90 - Intel Pentium D 805 Smithfield 2.66GHz LGA 775 Dual Core,EM64T
$195 + tax and shipping. If you want 1GB of RAM, its only $40 more... $95 - AMPO 1GB (2x512MB) DDR2-533 3AMD2533-1G1K-R
Or go for a single core amd athlon64 w/1gb...
$110 - COMBO: AMD A64 3400+ w/ ECS KN1 Lite 1.0A
$30 - ZALMAN CNPS7000B-ALCU 92mm CPU HSF
$110 - GeIL 1GB (2x512MB) DDR2-667 GX21GB5300DC
$250 + tax and shipping
Don't go to CompUSA unless you absolutely have no other choice. Fry's is much cheaper, and Newegg FTW!
He really doesn't need to build a new one if all he uses the system for is web browsing, email, word processing, and coding.
Your computer is okay for general computer usage. You could wait until Black Friday and pick up a decent computer from Fry's for like $99.
I built a PC using old parts that people gave to me and gave it to my sister as a spare PC and for general uses, its fine. It's a PIII 500mhz coupled w/ a gf2 card and it had 512mb of ram.
I have an old PII 266 mHz with 386 mg of RAM that runs pretty snappy, of course all i have done is a little internet with AIM running in the backround, but i didnt think it was that slow for basic things until i got on this computer, E6400 with 2gb of RAM
It's Xubuntu (with XFce). I might give the new Slackware 11.0 a shot.
