jhatfie
- Mar 19, 2003
I recently got a bunch of overtime and with some of the extra funds I want to pick up a second HD 5850 and give eyefinity a try.
However, I am currently only running a single 3 year old Samsung 245BW 24" 1920x1200 monitor. It was a pretty good panel for when I purchased it and I have no complaints other than the regular TN panel limitations. I found second used one that I can pick up for about $100 in perfect condition. Leaving me a need for a third monitor. I am thinking a Dell U2410 since it has a display port connection and I could make it the center screen since it will be the one getting looked at the most and needs to be the prettiest. Would this be an acceptable solution? Bezel's are not the thinnest on the Dell or Samsung, but are not that bad. Overall a total investment of around $830-ish ($100 245BW, $280 HD5850, $450 U2410 = $830)
Or should I sell the Samsung and start fresh with 3 matching monitors better suited for eyefinity? Would like to stick with 24" and 1920x1200 resolution if possible, but not mandatory. And no, 3 new Dell U2410's are not in the budget as I want to keep it around/under $1000 extra investment.
