If you hadn't mentioned ASIO I never would have known anything about it. It was just some little control panel I didn't understand. Figured it was for some device I didn't have.
Doing a little research there's a plugin for windows media player as well, but I went ahead and tested it. It bypassed the Xonar DX audio center and the signal going into the speakers became much stronger and apparently cleaner than before. There is a telling difference in the bass, though I can still hear a noise on the speakers when they're at higher volume. The noise remains when I unplug the line-in, so I suspect I know what's the offending party there.
When I get the new speakers hooked up maybe the difference will be more obvious, since the Bose setup with its built-in amp seems to be causing a lot of interference.
