I'm in the market for an LCD for the first time, moving away from my NEC 22" CRT. For what it's worth I have my eye on the new Dell 2408WFP at present. Being new to the LCD realm, I've been doing my research on different panel types, manufacturers, and specifications. I decided on the Dell because it was an 8bit panel and S-PVA is said to produce best viewing angles, better color range and deeper blacks than TN's or S-IPS's. Now one thing every manufacturer advertises is the response time in ms. I always thought of this measurement as the time it takes for the pixels to shift colors. After reading more about LCD panels I have learned about input lag. And I thought of this as the difference in time it takes between mouse movement and screen response. Am I wrong on these two points? According to wiki, a S-IPS is the best for no to very little input lag, but suffer higher response times. So what I am wondering is what exactly is response time? What does this mean visually when playing a fast moving game for instance? What would I expect so see on a panel like S-IPS with a poor response time? I have no base of reference having never owned an LCD.
Today I went to my local computer store and played CS on an Acer P243Waid. This panel has 3000:1 contract and 2ms response and is TN. My thinking suggests this panel would be great in responding to my actions but I found that the delay in input was very noticeable. On my CRT, when I put my crosshairs on a baddy, that's exactly what happens. On this screen I was constantly overshooting the crosshairs position and had to correct. So I assume this is not bad response time but bad input lag? I thought it was awful and I'm confused why TN's are considered the gamers panel. I'm curious how the game would play on an Apple S-IPS. With no input lag, but bad response time, I have no clue what that actually means. I am hoping that you might shed some light on this for me.
Here's another thought. If a S-PVA panel has poor input lag, would that not mean that when I play a DVD for instance the audio would be out of sync with the picture? That would drive me crazy. I cannot find any PVA panels at local computers stores so I am going to rely on your feedback to help me understand. Much appreciated.
