So, messed around with my new build, figured I would add in my old IDE 30 gig with some files, copy em over and start having fun.
Well I unplug my DVD rom drive so I can move the ribbon around easier. Plug my little 30 gig in, set it to master via jumper (currently plugged in the middle spot on the ribbon) then plug in the DVD.
Computer boots, sees my raptors and the DVD but no 30 gig... :sadface:
Plug just the 30 gig in, boot, sees it and is working great (I used the end of the Ribbon not the middle spot this time) Okay cool, replug everything as it was, 30 gig in middle set to master, end with DVD. Sees DVD, no 30
I will try messing with the jumpers, try just the 30 on the middle slot with no DVD, and also try another ribbon when I get home tonight.
IDE, why do you hate me so
/Rant
/Most likely user error
/Rant
