I see 6's and 7's, but I really wanna see 8's.
Too hard to really make sense of all of it. I'd rather see the difference between the 650 Ti not the 640. That's not really a fair comparison at all. TDP is nice though.
Ionno if it folds nicely which i doubt it, but arch changes could mean changes there as well, might be a nice thing to shove a couple 20nm maxwell cards for efficiency. I guess it's mostly excising for laptops graphics. And depending on how it scales might work wonders for their flagship at 20nm after all more performance often comes in form of efficiency, as graphics card coolers can only dissipate so much heat and thus watts so improving performance per watt does more and more as you scale up.Ok... I'm supposed to be excited right?
of the fiscal year i assume putting it sometime past April.
55-60W tdp is impressive for the punch those two cards offer.
A lot of good questions.It'll be interesting to see how Nvidia handles the 800 series as well as subsequent 900 series. Will they hold back the largest version of Maxwell like they did with Kepler? If not will 800 series be largely disabled? How will they refresh for the 900 series then before Volta?
Also what will the memory bandwidth situation will be. Volta is at the moment said to get a large bandwidth jump via stacked memory but currently GDDR5 is basically pushed to the limit now, it is highly unlikely they can raise memory bandwidth further simply via clockspeed increases (as with the previous few generations). Will mainstream performance finally move beyond 256 bits? Will Nvidia also go to 512 bit for the high end? Possibly GDDR6 ready?
This is the slide that is the key, and I am surprised wasn't in the OP:
(thanks Videocardz.com)
Nvidia is claiming first-gen 28nm Maxwell is 35% more performance per core, twice the power efficiency, *AND* that they can fit that performance in less die area. Add in that Big Maxwell (Maxwell second gen for GM200/204/206 confirmed through drivers) should be 20nm in the second half of this year (hearing rumors it'll be around July but they're just rumors) and we're looking at a monumental performance upgrade like one we haven't seen since the 8800GTX days over the 7900GT.
Think about it.... they're saying a 170% boost per watt, or in other words 2.7x the performance per watt used. And that's without 20nm yet. 20nm will allow a lot more transistors for the die size area, obviously, and the Maxwell SMM's are already smaller at 28nm than the Kepler ones were.
It's going to be one hell of a good ride for GPU's this year if GM200 shows, which it seems very likely that it will on 20nm. I'm looking forward to seeing what the competition brings too.
The thing about using a GT 640 as a comparison card is that it's all over the map. It handles some games well enough and handles other games really badly. I have no idea whether COD Ghosts is one of its better or worse games, so I have no idea what that slide is telling me.
That's impressive honestly.
By my thinking, wouldn't that put something like a mid-range future GTX 860 series card somewhere around a GTX 780 performance at less than 200W given the new SMM cores from Nvidia at 20nm?
July would mean it is already taped out, possible but not likely, and mean A1 silicon, extremely unlikely. Late Q4 is the more likely scenario with maybe a GM204 in July/August.
Yeah, as I said, simply rumors on the dates. I'll throw my guess in the pile though and say 860/870 in July (end), and 880 at the beginning or so of September or end of august. Again these are just guesses, based off of personal speculation.
Re taping out... Supposedly it taped out at the end of December.
Huh? I think you are reading it wrong. I said 2.7x As fast by those numbers, or in other words 170 percent faster. Those aren't my numbers but Nvidia's claims of efficiency and power draw potential.Edit- Forgot to mention you are doing your math wrong too.
Something did, not GM200.
Take a look at the Kepler timeline for why Q3 is overly optimistic for GM200.
The gt 640 has zip to do with the slide I posted....
