Guys, just so you know... you're gonna need AMBIENT temps of 30-35C inside your case in order for this GPU not to overheat. And you will need some pretty good airflow for that to happen.
Meh my 8800gtx idle'd at 63 deg and hit 76 on most games..
Thermalright HR-03 + HR-11 it idles at 46 deg and gets up to 63 under full load hahaha..
Chips can handle it these days and with a bit of cooling they are fine
Uhh russian, I highly, highly, doubt that statement is true. The vast majority of computer cases come with low powered (silent) fans, not screamers reminiscent of the 6000rpm Delta 80mm screamers used on heatsinks heh... I'd bet less than 1% of people considering buying GTX 280's have a computer case with an ambient temp of less than 35C. Thats just not realistic. If you're considering buying a GTX 280, you probably have a computer with at least 2 hard drives, a sound card, and at least 1 optical drive. These components produce heat, not to mention the GTX 280 itself.
