Thanks for your comforting words, Frychiko. I read somewhere (I read so much in the past couple days I don't know what and where anymore...) a poster claiming that by the time he lowered the brightness to what he thought would get him accurate colors -- the colors got hardly distinguishable... But he is using his monitor in a very low light conditions, while my office is pretty much lit...
DaverJ, I was considering the Apple 23" but I really would like to take advantage of the extra 1" real estate, yet save couple hundred $...
I read a bit about the different "Panel Technologies" and learned that in general, S-IPS is better, more professional and expensive than the VA (S-PVA and MVA) and then there is TN which is the least in quality and price. I see that the Apple widescreens use S-ISP, while the rest of the comparable ones use S-PVA or MVA (including the much more expensive Eizo)... But then, again, somebody was complaining about S-ISP technology too...
You might want to check out the NEC2690wuxi. It has a 25.5'' display with 1920x1200, covers 91% of Adobe RGB colour space and has a S-IPS panel. Its more expensive than the competition but has the advantage of possible hardware calibration via its internal 12-bit lookup table. Also check out the Dell 30'' 3007WFP-HC (also with 92% colour gamut) with its massive 2560x1600 resolution and S-IPS panel. This one needs a dual-DVI signal and has no inbuild scaler, so can only display the native resolution and a quarter (1280x800). This is the one I will go for as it sells for less than the NEC around here (UK). I dont care about HDMI and hardware scaling as it will be solely connected to my PC, so always on the full resolution.
