Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yeah for this kind of usage, you're better off with a prebuilt PC. Yes that SSD is a nice touch but from a best bang for the buck value, you're looking at a prebuilt.
With that said, my thoughts on that build is:
- Ditch the Corsair SSD and go for the Crucial C300 64GB SSDs since they are significantly faster in real world situations
- At $130, that CPU is overpriced considering that you can get the faster and quad core Phenom II 955 CPU for $10 more. So if you want best bang for the buck value, you're looking at AMD. The AMD Athlon II X2 250 CPU is more than enough for those usages. Find a mobo using the 880G chipset.
- At $40 shipped, that case is over priced. I recommend this case: $50 - Cooler Master Elite 430 RC-430-KWN1 ATX Case
