OEM CPU
mis3
I am waiting for a E8400 and my local store just called me that they have received only the OEM version of this processor.
Is OEM any good? I do plan to put on a Freezer Pro 7.
PaHick
OEM is no different than a retail boxed cpu as far as function. the only difference is the warranty period.
mis3
I thought the only difference is with or without HSF.
How does the waranty differ?
mis3
One year is not too bad. I plan to OC moderately, 3.3 GHz....
Would you buy a OEM CPU?
wolf2009
as soon as u overclock warranty is nulled . so it doesn't matter if u buy oem or retail.
yes i would buy oem , costs less than retail .
RonB
If the price of the 8400 is good then get it. I got mine for 190 and love it. See how high the prices have gone and can't believe it.
mis3
I can get an OEM E8400 in Toronto for $209, this is a $50 reduction than the boxed verison.
I have had a few PC over the years and they all had boxed CPU. I usually OC moderately, 10-20% increase in FSB but I never had a CPU which went bad on me yet. I guess an OEM will be fine.
wolf2009
it's when you make a mistake. ;)
there was a thread in here on that . there was lot of technical mumbo jumbo . so long story short , there is a circuit on which some residue is left by passing of current. so if more current passes ( overclocked ) than intel had anticipated , they know that the cpu was overclocked.
Neocorteqz
kinda like the anti tip stuff in the stuffed animal machines.:D
