Hello all. I am a bit of an odd situation and I am a little desperate to get it resolved.
I have a PC that I built in 2006. I boot it up 2 nights a week to play an old video game and I have been doing this without ANY issues for the past 4 years. For various reasons, I need/want to keep this setup to play this particular game.
A couple weeks ago I physically moved the PC in question and that is when the problem began. The first time I attempted to boot it up after the move, the fans spun up for about 1 second/1 rotation, then everything died down. I took the cover off and noticed a 3-pin connector with 1 blue and 1 black wire was disconnected from the mother board in the for the PSU FAN connector. I reconnected this and it booted up.
However, later that night and going forward over the past couple weeks, the PC will NOT boot up when I hit the power button on the front panel. Same thing will happen, press power, fans spin for 1 second/1 rotation, system goes down. Subsequent presses of the power button produce no action/no fan spin. I see nothing on the monitor and there are no beeps.
The only way I can get the system to boot up is to do the following procedure: Turn the PSU off using the rocker switch on the PSU itself; Hold the front panel power button for 10-15 seconds; Turn on the PSU via the switch in the back; Hit the power button normally. System boots up and everything runs fine for the duration of the night, 4-5 hours. I can restart and the system stays fine. After being on for 4-5 hours I even powered it down for a couple minutes and then powered it back on and it came up fine. However, this morning I tried to power it on normally and it did not come on.
I never had ANY of the problems described above prior to moving the machine. When the machine was moved, I would say it was done carefully. It was upright the entire time, may have encountered a few bumps.
What could this be? Is it a bad PSU, or a bad cap on the motherboard somewhere? I triple checked all connectors. I even cleared the BIOS (not sure why). The only thing that works seemed to be the procedure described above. When I do that the machine has been working as expected. Since I do have to hold the power button like that while the PSU is off, it seems like a capacitor type of thing? But I really don't know what to look for, which is why I seek help, and I also don't know if its fixable/addressable.
Machine specs: ASUS M2N-E motherboard, ANTEC TruePower 2.0 550W PSU, AMD Athlon 4200+, 2GB Corsair XMS2, nVidia 7900GT.
TL;DR: Have an older PC from 2006. Physically moved its location (somewhat gentle, upright whole time). Now when booting the PC for first time, fans will spin for 1 second/revolution, then everything stops. Subsequent pushes of power button do nothing. To start PC successfully I can turn off PSU via switch on back, hold power button on front panel for 10-15 secs, turn PSU switch back on, hit power button and it boots normal.
Any input is appreciated. Thanks
