Basic Outline:
Abit AV8
AMD 64 3500+ (winchester core)
1Gig PC3200 Corsair
BFG 6800 GT OC
Audigy2 NX USB
Fixed 33/66mhz PCI/AGP
When I run at 220FSB all seems to be stable at first.
Prime95 runs for hours on end and Mem test it fine.
I run fine at around 2.420Ghz or thereabout. The problem happens as soon as I go to play Counter-strike source. I crash the second the first ingame graphics load on a level. It's a hard, kill your system crash everytime. I reboot and am back to Prime95 and the memory test...both run without fault. The memory is running well within spec and nothing seems weird.
I dropped the Multiplier down to 5 and run at around 1ghz to ensure that it's not a CPU heat issue. Running at that speed with about a 220 fsb and I crash out IMMEDIATLY in Counter-Strike source again. What could be affecting me if my PCI/AGP are locked and it's clearly should not be a CPU heat issue?
it seems to me something in my system doesnt like the higher FSB speed? What on earth could it be? Shouldnt everything else be locked into spec at this point? I am overclocking my vid card to 410/1100 core/mem. I don't imagine that is the problem though as AGP is locked and it runs 100% stable at those speeds with the stock CPU speeds.
HELP
-Sal
Abit AV8
1Gig PC3200 Corsair
BFG 6800 GT OC
Audigy2 NX USB
HELP
-Sal
