Odd issue...POST trouble...experts come in!!!
TheRapture
Let me start by saying I have been building rigs for over 10 years....but everyone can miss something....
I have a Gigabyte GA-965-S3 board along with a C2D 2.66ghz, I am getting no POST action and no video output. All fans are working, hard drives spin up, etc. I have also left all the drives disconnected, same difference, no POST.
I have ruled out ram issues.....swapped back and forth with known good ram.
I have ruled out vid card issues, used a known good card.
If I remove the cpu from the socket and power up, I get a constant BEEEEEEEEEEEEEEP, never stops until power is off.
If I leave the pci-x power off the 8800gts, same thing, a long continuous beeeeeeeeeeeep.
If I remove ALL the ram from the board, I get NO BEEPS AT ALL.
The stock Intel heatsink is getting VERY warm, very quickly. My experienced guestimate is ~70c, way too hot for a cpu sitting in BIOS. I THINK the motherboard is bad, seeing it has no error beeps with all the ram completely removed. I THINK the cpu is overheating almost instantly and shutting itself off, maybe the board is juicing the voltage to the cpu?
Ideas? I am about to order another mobo this evening......unless someone can give me some compelling reason to suspect another part, the cpu maybe.....everythung else checks out.
I would put a suggestion of CPU, the board seems to get to various degrees fo post (albeit without the display coming on) when different things are removed.
I think try the cheapest component first, or the most suggested one!
It never gets the single "beep" to indicate a succesful post....I guess if I got motivated enough, I could tear my own board out and slap the new cpu in it to make sure it isn't the cpu...but damn that's alot of work...I have to remove my board to get the heatsink off......
