OCZ & SLI
lee63
Would PSU in my sig be good for SLI? Im thinking about getting an A8N SLI Premium and one more 7800GTX.
Thanx in advance
Thanx in advance
Well it isn't an SLI rated PSU......or even an ATX12v2.0 PSU. You can give it a go but I generally don't recommend it to people simply because I am pretty conservative when it comes to PSU's.
The 520ADJ can handle it with no problem. It can do 33A on the 12V rail, has a 24-pin power connector and one PCI-e (you'll need an adapter for the second.)
As Spectre stated, it's not an ATX12V 2.0 PSU, though. It doesn't have dual 12V rails. But I've found the rails are fairly stable and can take a lot of abuse AS LONG AS you don't crossload it. With your components, I don't think you'll be crossloading any PSU anytime soon, so you should be fine.
Spectre said:
"Have fun storming the castle"........wait that is something else.
Normally I would add to that with:
"Think it'll work?"
"It would take a miracle."
But in this case the 520w will run SLI without said miracle ;)
