Neo_Cloud_99
- Apr 18, 2001
Has anyone else gotten ahold of one of these to try it out? So far it doesnt seem to be affecting my FSB gains with my RAM. Maybe im just not using it right or maybe my RAM has reached its limit no matter how much voltage I pump into it.
Anyways I'm using the NF7-S v2.0 and some Corsair XMS 3200XLL series? Its rated at 2-2-2-5. Using a modded BIOS I'm able to hit around 230 FSB at the lowest timings with no errors and at 2.9vddr. So I try pumping the voltage up with the DDR Booster to 3.2 or even 3.4 and I cannot get it stable at 235. Ok yes this RAM is getting pretty high up there but hell I would figure with that much voltage it would at least squeeze out another 5 points.
So I dunno if I dont have this thing installed right or what. I have tried it in DIMM slot 3 and 1, both seem to have the exact same effect, and I prefer to keep it in DIMM1 so I can keep Dual Channel Enabled. I know they say to use DIMM 3 but it doesnt make a difference from what I've seen. I have it all hooked up right with the ATX power adapter and the 2 power cables that plug into the chip itself. I have tried using the MBD vddr setting of 2.9 vs. using the Booster vddr of 2.9 and they both seem to work equally well. No matter what I try though it just wont go past 230.
Any suggestions/comments?
Thanks
Thanks
