clayton006
- Jan 4, 2005
Hello all. This is my first attempt at overclocking and I think I'm doing well so far.
I'm using a SilverStone Nitrogon NT02 and some antec silver compound. (Yes I know it's not artic silver and I plan on picking some up very soon)
Well I have it installed, but I think I need to re-apply the thermal compound because I probably used too much. It seems that Artic silver's instructions differ from what antec says.
At 3.0GHz, my CPU idles at 52-55 using TAT and it's been running orthos right now for about 6+ hours and stays right at 70c. I know it should be cooler than that, but I think it's my compound that's not making a good connection. The fan is blowing fast, and in the right direction for the fans in my P180.
Any other suggestions? Oh and my voltage I think is at 1.31 or 1.32 on the CPU.
I guess my question is, I think I want to max out at 3.2GHz, is it ok to be running these temps like this... or should I be shooting to get this a bit cooler?
