Dark_Seph said:With the beta 15 bios, if your 1.0 version of the Kv8 Pro does not support AGP/PCI lock are you SOL? Or do the bios still work?
Also does any one have a link the the beta 15 bios
Thank you in advance
From what i have read, if you havea 1.0 and the new 15 BIOS.... then it will not work... and yes your SOL...well see if there are any newer BIOS files that have working PCI locks on the v1.0 boards...
