Just a quick question; Would it be safe to just set my CPU Voltage to 1.5 and the FSB to 400(Will give a 3.6Ghz OC and a 1:1 Ratio) and test to see if it is stable? And if it is, slowly lower the voltage until it becomes unstable? Or would it be much safer to just go in 10mhz increments?
My Temps are fine, 29C Idle for CPU and 43C Idle for MCP. I am using the Thermalright Ultra 120(CPU and HSF Lapped). Thanks.
