Ok, so I am pretty confident on the following parts:
C2D E6750 2.66Ghz (1333 FSB)
Asus P5K-VM or Gigabyte GA-G33M-DS2R
Unknown brand memory DDR2 - 800 or 1066
Now here's my problem. I am unsure as what speed memory I actually need to purchase. The motherboard specs show DDR2-1066 as the memory standard, but 1333/4 = 333 which means I should only need DDR2-667 memory.
Also, I plan on doing a small overclock (up to 3.0 Ghz). I already know I probably won't be able to simply use the multiplier, so upping the FSB will be required. A bus speed of 375 will give a CPU freq of 3.0 (375x8), but 375*4 = 1500 FSB after its quad-pumped. Am I right in this way of thinking on the quad-pumped FSB? Does it need to be 1333 like the proc was rated at?
All help is appreciated!
