A couple of weeks ago, I found the BIOS settings to push my Kingston RAM to the fastest, 533 MgHz. or 1066, speed. This was just pushing up the RAM voltage to 2.2 volts and adjusting the ratio setting. And I ran the system for some two hours and then had BSoDs. So, I set everything back to default and everything ran fine. Several days ago, I again, tried the RAM overclocking and the system ran 15 to 45 minutes and went through a single BSoD and recovered to repeat the process. Following the system overclocking guide from this forum, I adjusted CPU, MCH, VTT voltage to stop the BSoDs, at times it appeared, I extended the time between the BSoD happening, but didn't stop them. Then I had problems, that appear to be from file corruption and the system, OS, are pretty much bombed. In hindsight and the struggling experience from a NVidia 680i and 780i MBs, I think one or more of the memory modules,failed in the first try and the BSoDs were the result of. It appears moving back to the stock performance is fine. I tested the modules in a single DIMM and double DIMM mode for over 30 minutes, no overclocking, until my system fell apart. Did I do this process wrong or was it a failure of the RAM to tolerate overclocking?
