Oc'd quad w/ Antec 650W PS...
caw2007
Hello everyone..
I'm running my Q6600 at 3.6GHz with no problems except I get on and off stuttering during Video and Audio playback. I don't get any shutdowns or obvious issues that could point to an unstable overclock (even down clocked it to 3.2GHz) or bad board or anything like that. Could it be the PS? I know Antec doesn't have the greatest rep ever, but I've never had a problem with them before. I think it has 3 12V rails, so I wonder if maybe I need to move to a single 12V rail PS? I've been chalking it up to a bad Vista install up to now. Thoughts, suggestions? Any info would be greatly appreciated. :D
Its not the power supply, you could be running the Q6600 system in your sig with with a 450w power supply if you wanted too. Are you getting HD access during the stuttering? Have you tried a different media player? Got the latest drivers and all of that?
Got latest drivers, happens no matter which media player I use. I have two 80 gig WD's in RAID and one is a bit older, but they are both 8MB cache drives, same speed, SATAII, etc..
Do you have problems when running stock speeds?
Have you tried different driver versions? Sometimes the newest aren't always the best.
For CPU stability, run Prime95 to make sure the overclock is stable.
Is your PCI-e frequency set to 100? If not, lock it there.
What kind of video does this happen with? Is it HD video with a codec like x264? I've had HD video skip a bit on me for seemingly no reason even though my system is more than powerful enough to watch it without breaking a sweat.
There is a chance you RAID setup is going bad or one of the drives is dying.
Your problem could be hardware or software based. I highly doubt it's your PSU, though. I have a system similar to that (minus the power hungry video card) on an Antec Earthwatts 380. The system in my sig is running on an Antec Neo 650 and at full processor load but not full GPU load, it pulls about 255-265 watts from the wall.
