So ive had my e6300 since about may-april, been running it with a 7600gt so haven't really worried about overclocking much, but upgrading to an 8800 here in a few days so working out to see what i can push my cpu to.
I used this thread as a baseline to help out some: http://www.hardforum.com/showthread.php?t=1198647
The problem is, i got it up to 7x333 and it was running stable there, almost zero change in system temps. But up and around 340- and above it started getting screwy. 340-345 would sometimes post, but not boot into windows, and anything above 345 wouldnt post at all. So i figured it was about time to notch up the vcore, did that but to no avail, still couldnt get it to post no matter how much power i gave it. Running back at 7x333 with no problems at all, good temps and stable. I'm pretty sure i should be able to get higher than this, but not sure what the problem i'm running into is.
System Specs:
C2D E6300
GIGABYTE GA-965P-DS3
OCZ S.O.E 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) 5-5-5-12 (x2)
BFG Tech BFGR76256GTOCE GeForce 7600gt 256mb
any other info anyone would need just lemme know.
System Specs:
C2D E6300
