OC CPU/Mem Question
Z
Ziontrain
Guest
My motherboard isn't very overclock friendly first of all. I was seeing if I loosened my mem timings OR changed 400mhz to 333mhz I would be able to overclock my processor more. Also, when I change the FSB, does that also overclock my AGP card and sound card also?
Yes, you'd probably be able to OC your processor more if you moved your memory to 333 vs. 400. The reason is your memory is also being OCed, and the 333 will give you a little more headroom to up the FSB.
FSB OCing shouldn't affect your AGP card or sound card. If there's a place there to lock the PCI bus at 33 mhz, do that. Most boards that allow OCing also lock the PCI bus for you when you adjust the FSB beyond normal specs.
