sladesurfer
- Feb 4, 2006
On what OC are you running your CPU 24/7?? Im running my E6400 @ 3.9 for everyday use/gaming/24/7
On what OC are you running your CPU 24/7?? Im running my E6400 @ 3.9 for everyday use/gaming/24/7![]()
Not useful if you've got F@H running 24/7.Sorry to dredge up a slightly old thread....
I was wondering if others had experimented with CPU throttling along with overclocking?
I've got an Opty 175 slightly overclocked to 2.4Ghz... and I run it like that 24/7. But at the same time I have Cool and Quiet turned on... and use the "Laptop" profile in Windows... so the cpu is usually running around half-speed... and only when I need it, does it jump up to 2.4GHz.
For me, this is the ideal situation... using SpeedFan to control my fans... my comp is absolutely silent until I play a game or something.
It seems to me that this would be the ideal way to overclock, because your CPU isn't burning itself up all the time when you're not using it. Anyone else run it this way?
Friedmud
