oblivion red showing stats
Island
hey...I been noticing that under my stats for intelligence...it normally is green and is at 65..Now it's been at 64 and is the only stat that is red...I know that it's being drained, but how do I check why? When I highlight it it just explains what intelligence is for but doesn't show why It is draining..Any1 help me out?
To answer your question. Go to magic tab > all the way on the right. You'll see that it will show anything, armor, disease, etc that changes your attribs.
Most potion shops sell cure disease potions etc, awesome if you can afford it and are too lazy to go to a temple.
Plus my alchemy sucks :p
I often end up with red intelligence or willpower even though I have no "ill effects" showing anyplace I can find. I have no idea what causes this. None of my gear has negative on those stats, no spells on me etc. I have yet to figure out how to fix it.
You could also be wearing a peice of armor that is causing it to go do.
My shield drops my light armor 5pts.. but i wear heavy so no biggie.
Look at other gear besides armor/weapons? Did you do the Dark Brotherhood quest line?
