I am having a slight issue here...
For some reason I get Green and purple lines in 2 videos I have (random video files, divx i assume when not having the codec i hope), after about 5 min of playback. It also causes the mouse to get hieroglyphics on it and lock the system if I try to do anything. I'm at a dead end here... I installed divx / xvid codecs this morning. Video player = WMP 11. Haven't tried anything else yet as I am at work. I let an episode of heroes play this morning as I was getting ready for work and didn't see the issue. This happened within the first 5 minutes mind you last night.
E8400 CPU @ 3.6(9x400)ghz on 1.29v and 1.3v fsb. MCP at 1.525 SCP at
1.4?. Memory at 2.0v. And SCP<>MCP at 1.35v. CPU sits at 37c idle and
45 when running orthos (haven't had a chance to let it run for 12+ hours).
XFX Alpha Dog 8800gts g92 (512mb) SLI w/ 174.70 drivers then Driver Clean back to 169.21 same issue and updated to 169.44. Sits at 50C(atitool) w/ fans at 40% in rivatuner.
Card Default (what im sitting at now) 650 / 1625 / 970
What i had the card w/ no 3d errors 705 / 1905 / 1005
I did have card of to stable after using ati tool with no errors on
the 3d scan test. I have played WoW for 12 hours and let the system
sit an have ran 3dmark 2006 with no errors.
Anyone have any ideas? Is it just the g92's and their drivers? Or is
this a hardware issue? (hard to believe cause of the 12 hour gaming
session / 6 hour test on ati tool) Could I of damaged the cards? I see posts about these cards
going WAY higher... Plus I always checked my temps on them and they
were never above 62c with atitool running the 3d test or 3dmark going.
One thing i am going to try is booting into vista 32bit with the 174.70 drivers and seeing if the videos do the same thing...we'll see.
posted this on a few diff sites.... looking for feedback / help. Thanks a ton!
System is sufficiently cooled, specs are below:
Windows XP 32 Bit (vista 32 Bit Dual Boot, haven't touched vista yet though)
EVGA nForce 780i
Antec 900 case w/ all fans on medium
Thermaltake P0310 cooler w/ as5.
PATRIOT PVS24G6400LLK 4gb kit (2gb x 2) viper pc2-6400 800mhz 4-4-4-12 240
***unlinked sitting at 800mhz 5-5-5-12-2t
SEAGATE 750gb ST3750640AS SATA300 16mb 7200rpm
THERMALTAKE W0106RU toughpower 700w modularized ATX 12v v2.2 nvidia quad-sli / 80 plus certified active pfc power supply
EVGA nForce 780i
