Megalith
24-bit/48kHz
- Aug 20, 2006
VideoCardz’s sources are confident another GTX Turing graphics card, the GTX 1650, will be released next month. Predictions suggest this GPU will cost around $179 and feature 4GB of GDDR5 memory and a 128-bit memory bus.
This also confirms that GeForce GTX Turing series are basically called 16-series. The card is likely to feature smaller Turing GPU, presumably TU117. Apart from that, not much is known about the card. We have, however, heard it launches next month. Earlier rumors indicated that GeForce GTX 1650 was planned for ‘late’ March, which may still hold true.
