StoleMyOwnCar
- Sep 30, 2013
The current PNY stuff is really good. They aren't the cheap brand they used to be. Techpowerup said this about their 4080 Verto XLR8:
It's been a while since I've tested a graphics card from PNY, we all mostly know them from the professional-grade NVIDIA graphics cards that they produce. It seems they are making a push for the consumer market—no doubt to capture EVGA's market share that's available now. I have to say I'm seriously impressed by what PNY has delivered here. Their cooling solution is top-notch and can easily compete with the offerings from ASUS, MSI and Zotac. Having the most powerful cooler won't help any bit if your fan settings suck. Here too, PNY has done a fantastic job. Their card is actually the quietest RTX 4080 that I've tested today. Yup, even quieter than the premium offerings from MSI and ASUS. With just 26 dBA under full load, the card is pretty much inaudible in any setup that has other source of noise, like the CPU cooler or watercooling radiator fans. It seems PNY understands that offering great noise levels sells GPUs. MSI realized this many years ago, hence their stellar climb from value-manufacturer to tier one hardware company started. While other vendors include a dual BIOS feature with their cards, I see no reason why this is needed on the PNY RTX 4080. The card runs extremely quiet, and runs at super low temperatures of 64°C—what else could you wish for?
And they said similarly good things about their 4070 ti:
PNY's factory overclocked RTX 4070 Ti is based on the NVIDIA reference PCB design, PNY just added circuitry for their RGB lighting effects. The cooler on the other hand is a fully custom design, and PNY did amazing work here, just like on their other GeForce 40 cards. Our apples-to-apples heatsink comparison test that measures only the heatsink's capabilities reveals that PNY is offering the most powerful cooler of all the cards tested today. They also paired it with fantastic fan settings that are incredibly quiet. Just 28 dBA under full load is whisper quiet—even in a quiet room—very impressive. At this noise level, the PNY RTX 4070 Ti OC is the second-quietest card, beating all the other famous big name brands! Temperatures are really good, too, just 63°C is comfortably cool. What I really like is that PNY isn't hiding those great fan settings behind a manually-activated dual BIOS "quiet" profile like some other vendors do. As expected from all modern graphics cards, all GeForce RTX 4070 Ti cards come with the idle-fan-stop capability that shuts off the fans when not gaming.
Most of it isn't really the quality of their current cards, it's mainly their warranty, which I talked about above. I think most of the 4xxx offerings are pretty high quality at those price tags, build wise... the retention clip issue aside...
