Hi--
I setup two (2) 200GB hard drives (SATA) in a raid-0 on a nforce 3 based board. The system also contains an 80GB boot drive (IDE) and a 250GB drive (IDE). All went well and was working fine through the setup. It has been up and running for about three weeks or so. And now the machine freezes at the nvidia bios screen. It reads "detecting array..." and just sits there. I can't even get into the bios at startup.
I've removed the new stick of memory, reset all the drive cables, and still no luck.
Does anyone have any suggestions?
Any help would be very nice as I need this machine up and running.
Thanks in advance,
Ross
EDIT: Just flashed bios, still same problem. I've read about a problem with nforce3 boards from DFI...anyone have similar problem?
Thanks in advance,
Ross
