kcthebrewer said:Rivatuner allows 'higher' overclocks than what coolbits will allow.
Coolbits makes you 'test' the speed first, rivatuner does not.
Sorry, what he said.CheckOne said:That's not true, Rivatuner requires you test clocks before applying as well, you can get around it by changing a value in power user settings but unless you do Rivatuner still requires testing.
CyByte said:can you unlock any 6600GT pipes?
Yeah, only thing I don't like about Cool Bits.kcthebrewer said:Rivatuner allows 'higher' overclocks than what coolbits will allow.
Alowishus said:cant you also unlock pipes on the 7800GT with rivatuner?
CyByte said:I used coolbits and I did the detect optimal frequencies. it set it up for core - 565mhz and memory - 1.13 ghz.
Anyone know how good hte detect optimal frequencies thing is? It tested it and I choose for the fan to always stay on.
I have the MSI 6600GT good speed for it?
mrhemmy said:no, nvidia put something in to block people unlocking them
qbackin said:Negative. 6600GT is a no go.
What OC you get with your GT with coolbits?
