Fawkes said:I use the Marvell, but thats because the nVidia some times throws a hissy fit with my router.
Stellar said:nVidia, because the Marvell driver sucks.
Same thing. I was almost having an aneurysm trying to figure out why downloads that worked perfectly fine on my laptop were having problems installing / unzipping on my desktop. I finally uninstalled the nF4 firewall, and haven't had a problem since.ThreeDee said:I went to the Marvell as the nVidia was corrupting my downloads for some reason ..prolly cause of the firewall stuff ..dono for sure tho ..was pretty annoying there for awhile
I heard the opposite, the 3COM features higher CPU usage.thore said:on the a7n8x, you use the 3com, do to the fact the the nvidia uses some cpu power to do its job where as the 3com dosent, its a true hardware nic, assumeing they did the same here, then, again, you would want to use marvell, (but if the drivers are crappy, then use which ever one works... )
AppaYipYip said:Both of them work flawlessly on my MB. People who say "such and such driver SUCKS!" really should base their arguments on FACT and not subjective review.
Stellar said:What do you mean? The only facts we have are subjective review. We install the drivers, and they either cause problems or don't.
I didn't say Marvell drivers sucked because it came to me in a dream.
..not intentionally (I would hope) anyways..AppaYipYip said:Yes well CLEARLY manufacturers do not sell faulty products. .
ThreeDee said:..not intentionally (I would hope) anyways..
On a fresh install of WinXP Pro 32 or 64-bit ..load up chipset drivers w/o firewall stuff and after a bit downloads start getting corrupted on the nvidia nic and surfing starts grinding to a halt having to do the refresh madness to get pages to load. Hop on over to the Marvell nic and wow ..no problems at all ...hmm
so by your reason'ing .. can't be nvidia's product , or Asus , or Microsoft, or ActionTec or anyother manufacturer associated with my computer as manufacturer's do not make faulty products ..must be just me surfing to the [H] forums and typing thats causing it. ... darn , and I always fancied myself as a good typer.
that'll teach me
AppaYipYip said:Then why do both NIC's work flawlessly for me? I encounter none of your described problems? Oh, well it must be because the drivers YOU have suck?
