see thats what i thought but people kept telling me ati was better. so go with nvidia then? or do more research. i'm confused lol.
10.10e is slightly less broken than 10.12, but still broken.Welcome to my easy three-step alternative!
Step 1. Uninstall Catalyst 10.12
Step 2. Reboot
Step 3. Install Catalyst 10.10e
It's not hard.
The 5870 is about 7% to 8% faster depending on resolution, but given the price difference it's probably not worth it. 5850's have been down to $180 or lower recently, and you've got other good performers down there (460 and 6850) with good overclockability, it just doesn't justify the cost for the 5870, especially now that the 6950 is at $299 with the unlockable bios to 6970.whats the difference? isn't 5870 better than the 6870?
"almost no issues" still means he's having issues.My friend uses two 6850s with 10.10e and has almost no issues whatsoever.
Wrong. There's no way around it, it's a problem inherent to the drivers and everyone with these ATi cards suffers from it weather they realize what's happening to them or not.Just because you have problems doesn't mean everyone has probems. Using a Geforce in tandem with a Radeon for PhysX is bound to cause issues as well.
What's wrong with PowerPlay?PowerPlay is broken on every card from the HD5830 and up.
I thought I made that fairly clear...What's wrong with PowerPlay?
Oh good, this doesn't concern me.secondary monitors
Actually, it does. Read the rest of the post, the issue effects single-monitor users as well... you'll still be stuck in 2D mode even if you open a 3D application if you open a video, and you may suffer a Gray Screen of Death (GSOD) if you open a video.Oh good, this doesn't concern me.
For a second there I thought I was going to have to spend 5 minutes in Radeon Bios Editor. You had me worried.![]()
When ATi first released the HD5800 series of cards, they scaled core and memory clockspeed up and down depending upon workload using clockspeed values defined in the video card's BIOS. It was discovered shortly thereafter that changing the memory clockspeed caused the image on secondary monitors to jitter while the clockspeed changed (and in some cases, this even lead to instability and gray screens of death).
To sort out this issue, ATi tweaked the driver to keep the memory clockspeed at a fixed value (1000 MHz for the HD 5830 and HD 5850, 1200 MHz for the HD 5870, etc). As long as the clockspeed never changes, flickering and instability are avoided.
The problem is that they forgot to cover the PowerPlay state associated with DXVA2 hardware accelerated video decoding. It reverts to the old values defined in the video BIOS for hardware accelerated video, which are 400MHz core and 900MHz RAM. An additional side-effect of this bug is that the 3D applications (which should be able to request full 3D clocks) are IGNORED while a video is open and the drivers are in this glitched state.
End result? Opening a video leads to flickering secondary monitors, possible gray screen of death, and very poor performance in games since you're stuck slightly below 2D clockspeeds. If you close the video, everything returns to normal.
This issue has remained unresolved since launch-day, which can only mean one of a few things; AMD doesn't care enough to fix the issue, AMD can't fix the issue with a driver and needs to release a fixed BIOS, or AMD can't fix the issue in the driver and needs to recall the cards to replace them with new (fixed) revisions.
alrite i ended up just building a computer that was 12k that came with 4 gtx 580's i should be fine for a while.
Ergo, close the video and everything will be normal.![]()
I'm using a non-reference card with different clock values than the normal design.Edit: If you could post your BIOS once you've modified, that would be great.
