Guys I have problem with this card I don't know what to do.
I own Toshiba Qosmio X500-12D, if I knew all this I wouldn't buy it, but now it is too late.
My problem:
- dual display mode stress up my GPU to 100% and temps go over 100°C
- my fan doesn't speed up when GPU heats up
(while CPU heats fan speeds up)
Is there way to down-clock this card ? I tried EVGA but no luck, I need to put voltages down ... also is there way to speed fan up ? Evga can't do it, it is locked.
Thanks in advance. I read about 50 forum posts, and no luck so far.
I have 2.6 Bios (updated)
I tried all drivers from Toshiba to Nvidia latest... no luck.
I noticed that on battery if I stress up GPu, my VDDC (in gpu-z) doesn't go over 0.85 and temp not over 75°C MAX; while stressing on power supply it goes over 103°C ! And sometimes it shuts laptop completely. Not to mention that without cooling pad and even now, I get BSOD + shuts down if I play games ..
I do have cooling pad, it helps little bit, but without this fan speeding up, no much gain
Thanks.
My problem:
Thanks.
