Tesla to Fermi was a change in NVIDIA's philosophy to power above all else. They threw efficiency out the window and it showed in the lack of performance gains and heat generated. Kepler was the first architecture developed using their new philosophy of a balanced approach toward efficiency. NVIDIA had gotten complacent after the reign of the Tesla architecture. Still, ATi saw similar "anemic" performance gains during that time as they dealt with their own issues in design philosophy.
So you have code samples and application profiling results of these games to share with us to prove that?
This has been debunked several times. Lack of updates to a previous architecture's code base does not mean "gimping."
The testing parameters are laid out right in the article and they are consistent across the spectrum of tests, including game patches. What subjectivity are you referring to, specifically?
No, that is quality assurance at play because the hardware is not supported and the developer doesn't want to get complaints or support tickets for unsupported hardware. GPU architecture is more than the total number of transistors in the core.
The only variable in [H]'s testing is the RNG in the game loop because they want to provide us, the readers, what one can expect in real world usage. Benchmarking can't provide that. The most recent case of a benchmark being vastly different to the actual experience was Deus Ex: Mankind Divided and is a perfect example of why benchmarks should not be used as a metric for gameplay experience.
Seeing as you seem to lurk the FS/FT section and come out randomly every couple years to post thoughts in other threads, I've probably wasted my time with this post. But it seems that [H] is not the hardware site for you.
Sure."We are referring to NVIDIA’s "Ti" line-up in the high-end, the cards that let loose the full potential of each architecture."
Isn't this more accurate of Titan cards than Ti?
I had a 2K monitor in 2013. I went to 1440p in 2014.
I had a 2k monitor then, it was a big upgrade from my 1k monitor.Who on earth calls it "2k"?
This whole K nonsense is a TV thing introduced with 4K, and it is just plain dumb. I can see using it for 4K, but I'd prefer if people just called it 3840x2160. Anything prior to 4K should just never use that terminology.
Just sick of people calling 2560x1440 "2K" when it's really for 2048x1080, but can also be used for 1920x1080.Who on earth calls it "2k"?
Certainly, but even Nvidia themselves have now demphasized gaming as part of the Titan brand. The original one in 2013 was the GeForce Titan, now they've dropped the GeForce name from the Titan all together. It's just the "Nvidia Titan", and it is being marketed as a professional product machine learning and the like.
The sticker price has rocketed way way up, with the Titan V costing $3k...
I can tell you for sure, prices on 1080 will fall. When that will happen is whole other question.Is it possible to know if prices on GTX 1080 will fall?
