I wonder if Maxwell will be more powerful than the Ti?
every generation is faster then the last...dual GPU cards might last a bit longer but even those lines are starting to blur nowadays
the ARM cores are on a 2nd chip on the board not part of the GPU core
Probably posted before. But interesting to see that they are also making 6GB and 12GB VRAM versions of the GTX 780 Ti
12GB... crazy 4K times to come.
1200p does not use 3gb. I'm guessing the card probably allocate a lot of vram because you have 4gb. 1080p uses 1.6gb at ultra with 4x aa.
I just don't see the point of buying a Ti at $700 then. Even if Maxwell is 10% faster, it will probably cost around 550-600. I guess it's the cost of having the most powerful card first.
I could see if Maxwell was a year or so off, but it's about 6 months or less.
....It's been so long since nVidia understood competition I'm wondering if they remember how it works.
My understanding is that the ARM CPU is inside the GPU die. Have you read something different?
