I dont feel sorry for you when you die.
wave!
I don't feel sorry for you when you anger the invisible flying spaghetti monster and he comes for your soul with his noodly appendage.
wave!
I dont belive the double the speed of a 8800gtx. It would need huge amounts of stream processors which they havent stated, high clock speeds and shader speeds.
A rumor is a rumor and this is no different. It will be considered and discussed as a rumor, until we know for a fact, it's true or not.
And actually, most of R600 rumored specs, turned out to be true...Let's just wait and see what happens.
So I guess a comment to an article is a rumor now...wow I should post in some other forum some "rumored" G90 specs with no backup (just like this one) and it'd be considered too? Even if I made it up and no one really knew!?It's just funny to see the clamoring in this thread from some old rumor, I mean it isn't even a wide-spread one at that lol.
we obviously know that terrflops can flop too
look at the xfire 2900xts that hit 1tf![]()
I don't think that's correct. Even AMD's website says the 2900 features an "integrated HD audio controller". From what I can tell, even if you took out your sound card and disabled audio, you'd still be getting your audio.built in Audio Chip.
Riiiiiiiiiiiiiight again. Even on the HDMI ATI cards there's no sound chip, just uses a pass through from the sound card to combine the audio with the video signal to pass via the hdmi.
You superstitious fool! Don't you know that all spaghetti evolved independently from primitive single-celled fettucini?
Ehhh. I'm fine with my 8800GTS.![]()
E-dram = pure crap. PC's don't output a fixed resolution, the amount you'd need (and the cost) would be huge. If it really is going to be 512bit (and fast DDR4), bandwidth to ram would be huge anyway (over half that of Xenos's e-dram most likely).
This seems like the same shite thats happened with every bloody gen. Some geezer jumps around forums grabbing all the expected/desired buzzwords, wraps them up into a single post and calls it a "leak".
buying the Compusa replacement plan was the best 20 bucks i ever spent. i am so turning my 8800gts in when the 9800 gts's come out...
lol getto step up
not quite sure that you are talking about....
The audio coming out of the R600 is a realtek codec chip, its not cutting edge by any means, So having a separate audio card that pipes in the sound is still in my mind a better solution, nvidia should just work on a better interface with audio cards.
It pisses me off, people telling other people not to buy an 8800GTX/ultra because they think the 9800 is going to be out in a few months. Theirs still no hard evidence which is baffling.
Wow. Just wow.
If true I can make the final decision on my new rig... by a cheap 8800 now and replace in November...
