AuDioFreaK39
- Jan 10, 2005
I have a GeForce 6800 (not ultra or gt just normal) and i was wondering what would be the quietest and best cooling solution for under $40. Thanks in advance.
ryuji said:no fans all the way for me.. my friends 6800 ultra extreme(modded 6800gt) runs with no fan..
no lie i have seen it in person.. gets no more then warm to the touch.. like my card.. we got decent case cooling tho.. his pcs a bit louder then mineMeanieMan said:Bullshit![]()
ryuji said:no lie i have seen it in person.. gets no more then warm to the touch.. like my card.. we got decent case cooling tho.. his pcs a bit louder then mine
we sand the blocks and stuff to make them more efficient.. both our cards top out at about 60C without the 'optional fan'
hes perhaps not running at ultra extreme voltage.. but hes running past ultra for core and memory clock... i belive he said he couldnt get it past 500 core and 1.2 ghtz ram without it artifacting.. and thats why hes gonna buy a x800 xt-pe with phase change
he sure got a lot out of that card for what he paid for.. i did too... i bought a 5900 and got past 5950 speeds... perhaps were lucky bastards when it comes to getting chips that run cool/fast... i dunno
Stoopid Guy said:No fan, but it runs like an FX5200, except for about 2 moments each day![]()
FunkStar said:To quote a wise man from this very forum:
"Bullshit"
50C Idle / 65C Load
... still call bullshit?
AuDioFreaK39 said:120 - 40 = 80C
i want something cooler than that that will possibly end the noisyness as well and will let me overclock even higher
so which should i get?
ScHpAnKy said:FunkStar said:To quote a wise man from this very forum:
"Bullshit"
50C Idle / 65C Load
Actually yes, you'd have to throw up some in action video or something. Its easy enough to remove a fan for some pretty pictures.
Where is the side panel or window? Or are you making this claim with an open air case?
MeanieMan said:Actually yes, you'd have to throw up some in action video or something. Its easy enough to remove a fan for some pretty pictures.
we cut the window just days ago.. it ran for months without any window at all(yes.. sealed case) in reality.. open air actually gives the zalman a disadvantage, i open my side panel.. my video card goes from 32C idle to about 36C idle.. cant even imagine what a 6800 will do without a sealed caseMeanieMan said:Then that defeats the entire purpose.![]()
ScHpAnKy said:How so? You get better cooling if the case is closed.
Why imagine, he just said it was an open case.ryuji said:cant even imagine what a 6800 will do without a sealed case
MeanieMan said:Not with the thermalright. That fan moves more air then the 80mm fans can take in or exhaust. What it does is push air over the cpu, down over the card and out the case. Like a mini U-turn.
ScHpAnKy said:Thermalright makes fans? Also, at 60% speed the thermalright doesn't create enough air to cool the card at all. I don't see how having a passive cooler would be benefitted by a open-air case? Wouldn't a wind-tunnel effect be much more efficient? I certainly have one set-up.
MeanieMan said:The design of the thermalright, with the addition of the fan. If the fan didn't create enough force to reach the card then it would have troubles cooling the cpu as well.The air has to go somewhere, and only having an 80mm exhaust isn't enough for a CPU. Even if you did have an additional unseen intake fan blowing air over the hot hard drives. I see the bottom fan blowing in the bottom of the case, out the PCI covers, but that still leaves the top of the card to to the air blowned down from the thermalright design.
