Nvidia has released the 320.49 WHQL certified graphics driver. This driver is identical to the recent 320.49 Beta driver, but is now WHQL certified.
http://www.nvidia.com/page/home.html
I go try now BF3 i msg you.
Never messaged me back, does that mean your pc exploded?
if you did not know then all it takes is a quick google to see those are for Windows 8.1.What's the deal with those and 325.71 WHQL drivers released in same time ?
Hopefully my stock boost clocks will be raised from 1136mhz to higher+ on that drivers.After uninstalling 320.08.
why it won't install? do you have ati card?
Depends how old it isNah he has an AMD card.
why though? they were really only released for 8.1. there is nothing in them for games over the 320.49.But I'm using them for Windows 7 right now with my new gtx 770 ?
I reverting back to 320.08 BETA. On 320.49 now my temps in Crysis 3 increase 2C up.
2C + up on 320.49 than 320.08 drivers.
On Crysis 3 i get on the same place 80C on the 320.49 drivers
When on 320.08 get 78C.
GPU: 770 Twin Frozr all auto settings.
That's not a bug. That's how the 700 series' boost works. All the drivers did was set your thermal target at 80C, which is the same temperature as the Titan and the 780, IIRC.
But if reach 80C is too high even if this is a target yes?
I am just thinking why one time my boost go to 1123 and 1110 and then again up.
I was not in room at that time. When i back i see windows minimalized with WINDOWS ACTIVATION msg. Maybe this is the reason? Or something with GPU cause downclocked was?
Yeah, it's probably related to downclocking at idle.
