It works fine with 13.5 beta 2. It worked for me in the 11s and then got broke somewhere around 12.2 IIRC.
I also got made fun of for wanting the Nvidia control panel to support the same. I'm sorry, but I really don't want to have to arrange my monitors and setup bezel compensation EVERY TIME i switch.
I did surround and eyefinity back to back and had no issue with Nvidia settings breaking when I switched just the hassle of having to open the control panel each time, I set up surround once and it stayed the same every time I switched. Maybe it is broken now, I haven't tried it in a while. Both sides could use some improvment to make those setups easier to manage I think.
So you switched video cards rather than just getting an input adapter??The hotkeys on CCC did work for me. Did you do the setting inside CCC? Not extend/unextend the monitor in WINDOWS and save it on CCC right?
Also, the hotkey will only work on AMD video card. If you got Intel 4000 on it, it will not even see that integrated card.
I do miss the hotkey. Now I have to manually have to change the monitor and the audio setting each time I do extend monitors!
Why did I switch to Nvidia? Because AMD does not make any video card that has TWO HDMI.
Very sad all around.
My thoughts exactly...So you switched video cards rather than just getting an input adapter??
Input adapter? DVI does not do audio.
I need two HDMI with audio. One goes to my HDTV and one goes to my 7.1 receiver which goes to my projector.
Zotac is the only one that makes two HDMI port video card and its Nvidia.
WOW. I didnt know DVI can deliver audio.
OK, my > 2 yr old 7.1 Onkyo receiver is all HDMI input.
My 1 yr old HDTV is all HDMI input.
Do you mean get a DVI to HDMI converter?
I went to Nvidia forum to voice this just now.
Now Nvidia doesnt remember my HDTV to the left of my monitor. It always put to the right.
All in all, Nvidia suck!
