http://www.guru3d.com/files-details/geforce-344-65-whql-driver-download.html
Starting to get right on my tits this is now.
Displayport corruption? Does this only affect certain configurations? I do use Displayport with my Dell U2311h on a GTX 570 so I'm wondering if I should avoid these drivers.
If I remember correctly I am currently using 344.11 or 344.16.
The OP is referring to a issue with Displayport on GTX 970/980 cards. I for one think that this will not be fixed via a driver update and think it's a firmware issue or a physical component issue that is not correctable without a bios/firmware update or replacing the graphics card by those affected. Also not all people on displayport 1.2 are affected. Only some monitors with some cards.
Works just fine though on 344.11 and 344.16 - Driver versions after that are no good.
This issue didn't exist two driver releases ago (not for me, anyway), so its not a BIOS/firmware issue.
I just installed these new drivers last night after receiving my PG278Q. This is the first monitor I have connected using DisplayPort and I had no issues after constant use for 6 hours. I do not use any kind of sleep modes with my PC or display. The monitor is set to turn off after 15 minutes of inactivity.
I thought they fixed this awhile ago.
