Putting together a PC for my mother-in-law from some leftovers of my last build.
Just curious if leaving out screws from a motherboard installation might cause a short circuit. I have 6 out of 9 screws installed since I can't seem to find the other 3 at the moment, and the system won't boot. It'll turn on and get the fans going, but that's where it sits. No BIOS or POST beep.
Other possible factor:
350W PSU has a 4-pin 12V connector but only a 20-pin main connector. The motherboard has a 4-pin and a 20+4-pin connections (I was able to get the system working and OS installed with a 400W PSU that had the same 20-pin main connector, so it doesn't seem like that should be the problem. It also worked with the 6-out-of-9 screws installed)
The system was working fine at my house. It was working fine when I initially set it up at her place while she was at work. She came home and said she'd like the tower on the floor instead of up on the desk. I moved it to the floor and now nothing works...
