MB: Gigabyte GA-EX58-UD5
GPU: GTX 560 (new)
CPU: i7 920d0
Been scouring the internet for a while on this one.
About the day of or the day after i installed my new graphics card, i could no longer use the power button to turn my computer on or off. I can still go to the start menu (win7) and shut down that way just fine. system-wide performance is perfectly fine. once the computer is OFF, the ONLY way i can turn it back on is by hitting the switch on the psu and letting it sit for a second or two, and then re-enable the power to the psu, and THEN hit the power button. but the button will only work THAT ONE TIME.
google returned a few posts where someone reported their psu not handling the voltages correctly or something, and that when they put a new graphics card in, the psu just couldn't handle it for some reason (nothing to do with wattage, apparently). so what did I do? went out and got a new psu (modXtreme-pro 700w, OCZ) down from a presumably dieing corsair tx850. the new OCZ psu just came in today, installed everything, and voila... problem still persists. so i'm down 100 bucks and the problem has not changed at all
also, before you ask, yes i have tried manually shorting the power-on jumpers AND using the on-board power button (asw ell as resetting the cmos), but the problem seems to be within, as in, not button-related. any ideas as to what my problem is? if this is the ONLY problem that i'll have to put up with, i guess i can live with it until i buy a new board down the road.
(i'm a piss-poor student so i'll have to wait a bit)
GPU: GTX 560 (new)
CPU: i7 920d0
