Not impressed with Intel X-25 SSD
MetricGnome
Hey [H],
I got the 80gb Intel X-25M G2 SSD....and I am not really that impressed. It feels pretty much exactly the same as my WD Black 1TB drive did. I'm running Win 7 64-bit Ultimate on a fresh install /w default SATA drivers.
Am I missing something here? Know of a benchmark I should run to know if its actually working properly? It doesn't feel slow....it just feels the same, except my pc is slightly less loud.
You'd have to tell us what steps & settings you have done to install the drive...
ACHI mode in BIOS?
prefetch, superfetch, pagefile disabled?
Indexing disabled?
I'm running whatever is configured by default with Win 7 Ultimate. Why would I turn my page file off. . .?
Where can I check prefetch, superfetch and if indexing is disabled?
EDIT: Rebooted and I am running in ACHI Mode. However, my hard disk is on sata 4, cd drives 5/6. Should I swap them to 123?
Do some research on tech forums (like this lovely one) on setting up specifically Gen2 Intel drives. There are just a few settings like the ones I mentioned with the Gen 2s where the Gen 1s required a bit of tweaking.
The Vista speed guide is handy too. Keep in mind it is on OCZ's forums and may have comments only pertaining to OCZ's line of SSDs.
An important first setting to activate is to disable any defragmenting service or scheduler. Defragmenting a SSD will make it cry.
Changed some of the settings around in the link yang88she posted.
Any ideas here. . .?
C:\Users\Tom>fsutil behavior set disabledeletenotify 0
The FSUTIL utility requires that you have administrative privileges.
W7 should disable it for that drive automatically. You want to leave it enabled if there are additional mechanical drives in the system.
Well, after making those changes on that site....I can no longer shrink my volume and get this. *sigh*
ofcourse if you fresh install a g2 and a wd black both drives will perform well with a clean install.
But once start filling in your drives with data, the g2 will simply blow away any HD.
I simply have had zero performance decrease with bootup times, app load times, game loads from day 1-now. And I've had approximately 1tb of writes on my g2 now. Everything still loads instantly. Try achieving hte same results with any traditional HD, then come back and say you're not impressed with the g2.
first run CrystalDiskMark as a benchmark and post your #'s, so we can see if there is a performance issue.
second how much of the drive is filled? I noticed you have it in 3 partitions. Having the drive over 80% capacity can decrease performance. (we'd probably notice that from you benchmark, see # 1) Personally, I manually changed the partitioning to only 1 partition during the Win7 install process.
third have you installed Intel SSD Toolbox, run it and make sure you have TRIM supported. If you have Intel's (RAID) drivers installed, like I do, you need to set up a schedule to "manually" TRIM the drive weekly.
fourth if you're still not happy with it, I'll take it off your hands for $150. :)
Yes - I upgraded the firmware on the drive to the latest after my Win7 install.
I'm going to go ahead and start over with a new install without changing things around. Will run CrystalMark and play with SSD Toolbox and report back.
Would be nice if you gave some information as to what mobo you have. Intel chipset or nVidia. If its nVidia you will find if you did not change to microsofts controller driver and only using nVidia instead, your SSD will may not be getting TRIM command as it failed on mine at first.
Just reinstalling the OS again may even mess up the SSD even more (Lower performance) without using a Sanitary Erase program as happen to me. I either had to have an Intel chipset, with a 32 bit OS (Vista or Windows 7) available or find a system that did and burn the Sanitary Erase program to a USB memory key. I did not have this and had to send the SSD back to OCZ for them to do it. I learned the hard way but got my SSD from OCZ working well again, but will never buy another SSD until it matures even more.
Perhaps you should read up on the Intel SSD forum first and ask some questions as to their product before you go about reinstalling windows again and cause even more issues.
http://communities.intel.com/community/tech/solidstate
It's possible to be unimpressed with SSD if you have a light OS install and multitask very little.
or could it be that for a normal everyday user the benefits of SSD are just not there..??? that you can only appreciate the difference if you spend hours benchmarking hard drives?
That's what I'm thinking. SSDs are mostly just faster in boot time usually, and sequential read and write operations. Game maps should load silly fast, that's about it.
Actually, the increase in sequential reads/writes isn't what makes SSDs so much quicker than a regular harddrive. It's the multitudes faster random read/writes that create the sense of a faster experience, along with the nonexistent access time. Regular day to day use is a lot more dependent on reading and writing small files, like the Os temp files and browser cache. You could have a SSD with lower sequential reads and writes compared to a HDD, but the random access will make it feel faster. That's why people still notice a difference after going to a single SSD after running Raptors in RAID 0.
Hence my mention that boot time is the only real factor affected by this, as well as game map loading and such. Big apps like Photoshop with lots of plugins are supposed to load faster too. That's what I was trying to say without bringing up access time and other such things we already know about.
Your post explicitly mentioned sequential speeds. Very rarely do they come into play, as even booting up and loading games are mainly reading small files. The importance people put on sequential speeds is greatly misplaced, as very few people will load a single big file.
You are hitting RAM and various caches most of the time. When you start getting into heavier workloads is when your SSD is going to crush a disk. If your day to day consists of running notepad and firefox, you aren't going to be impressed.
HELL NO. If you do any sort of strong multi-tasking and/or if you work w/heavy apps (Photoshop, Outlook, etc) on a regular basis then the benefits of a SSD are VERY noticeable... If you're upgrading to a SSD on a laptop, where you're by nature forced to boot up or hibernate/resume on a regular basis (as well as load and re-load apps w/frequency), it's also very noticeable (since you're also typically upgrading from much slower 5,400 RPM drives).
However, if you mainly dick around on the web and play games, and you don't multi-task a lot, and you never turn off your system, then it's very possible you wouldn't be very impressed w/a SSD. Hard to say which camp the OP is, for my money (and my usage) the SSD upgrade was one of the best upgrades I've ever done, more so than moving to a quad core, easily... Or probably even than moving to 4GB from 2GB.
Most of the tweaks and stuff the OP has been messing around (as recommended by some in the thread) should be largely unnecessary unless the installation wasn't performed right from the start (in which case none of it is gonna help matters anyway). Since he never came back my guess is he was just trolling or he has the attention span of a gnat (which would fit with the first profile, and he probably didn't need a SSD). :p
I've LOVE to upgrade the HDD in my work laptop to an SSD. I'm even willing to pay for it out of pocket. I'm just worried that the full drive encryption will kill it much sooner that it would otherwise die. We've already had a bunch of the spindle based drives die with in 6-8 months of getting these new laptops.
I am running one in my work laptop. It's running FDE (full disk encryption) without issue. It is much faster than the old hard drive!
