Hi,
I have this latop that I know if severely infected. I know for certain it has the Total Security & Windows Antivirus 2009 malware. I have also found traces of Lampsy Trojan, Biforse Trojan, Lineage-AV Trojan.
I have been able to kill these manually. I beleive there must be more infections. Whenever I try to install or run ANY type of anti-virus/spyware/malware it fails. I have tried MalwareBytes, SpyBot S&D, SuperAntispyware, Asquared and some others. These programs will either install .. IE ... the installer shuts down right away, or they will install but as soon as a scan is initiated they are shut down ... and once shut down they will not open again.
I have tried the renaming of the scan exectuable files as I read in some forums. This has no effect. No matter what I try no program will operate. I know there are still infections because regedit.exe will not start, msconfig will not start, when I right click on my computer and choose "properties" that wont load either.
I can see that iexplore.exe is running, and whenever I close it, it restarts itself without actually showing the browser. If I delete iexplore.exe from Program Files another one spawns.
I cannot boot into safemode. When I try, the drivers start to load but eventually the laptop just reboots itself after a point.
This PC just has be stumped. I would appreciate any advice. Thank you.
OS
OS
