steakman1971
- Nov 22, 2005
I have a Gigabyte MA785GM-US2H, AMD Athlon2 2.4hgz. This system has been very stable since December 2009. I use it as an HTPC - mainly running Boxee.
This week, it developed some problems. I can't get it to POST reliably. Sometimes I can get into BIOS, sometimes cannot. Rare occasions, it will boot into Windows - but generally freezes pretty quickly. It is basically hosed right now.
I opened the case looking for a hidden peanut butter and jelly sandwich (kids!) - none found. It's relatively free of dust bunnies, fans are spinning, nothing visually wrong.
Next, I reset the bios using the jumper. Same results. Next, reseated the RAM (although the case hasn't been moved since December). No help.
Other relevant information:
Memory is OCZ, 2GB. It's matched to the CPU (speedwise).
No overclocking - just stock. Boxee is not a very demanding program.
2 Western Digital 500GB drives. One has Vista Professional installed.
1 Western Digital 1 TB drive.
DVD-ROM, Toshiba.
Power supply is OCZ - 700W if I recall.
I've taken all the drives out of the equation by disconnecting power and data cables. Same results. Sometimes it POSTS, sometimes not.
Any advice appreciated. I'm leaning towards a mobo failure.
DVD-ROM, Toshiba.
